First gaming pc.
lsc1
Would you change anything for similar price or upgrade anything?
Intel® Core™ i9 16-Core Processor i9-12900K (3.2GHz) 30MB Cache
ASUS® ROG STRIX Z690-F GAMING WIFI (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair DOMINATOR PLATINUM RGB DDR5 5200MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP, LHR
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Corsair iCUE H100i RGB PRO XT Hydro Series High Performance CPU Cooler
LED Lighting
50cm RGB LED Strip
1x 120mm Thermaltake TOUGHFAN 12 Case Fan
Monitor
ASUS XG27AQM 27" G-Sync ROG Strix
Monitor Cables
2 x 2 METRE GOLD PLATED V1.4 HDMI CABLE
steaky360
What's your budget and what will you be using the PC for?
Can you include the price for the configuration above and also its configurable link?
MrWilson
Are you buying this on finance? I generally wouldn’t recommend getting your monitor through PCS as you can generally get a better selection and value pick by shopping around, but if you do want to buy everything in one place I can understand that too.
I would be leaning towards an AM5 build for a gaming system, the 12900k isn’t really a gaming CPU and comes with a heavy premium. Intel 13th gen is on the horizon though if you wanted to wait for third party reviews prior to making an informed decision.
