First gaming pc Appreciate any advice
Dnblover
Hi I'm new to the forum and computers in general being honestšŸ˜… so any advice or suggestions I would much appreciate.
Looking to buy a pc to game in 1440p. My budget is Ā£2500 but I wouldn't complain if I could spend a bit less for the same performance.
I'll post the link to the build I have guessed up again any suggestions even different case extra fans etc
Many Thanks
sck451
Here's where I'd go for you, with a few tweaks. The 3080 is not necessary for 1440p: the 3060 Ti should be fine. The 3080 would be mega overkill. In an ideal world you might go for the 3070, but as it's out of stock the 3060 Ti should be absolutely fine.
I'd then change the motherboard, your storage solution, the power supply and get a separate WiFi card to give a really solid foundation for the build.
The only question I have is over the case: it has a front USB 3.2 Gen 2 port, while the motherboard doesn't have the header for it. I'm not sure whether this means the port won't work, or if it means it will be at a lower speed. If that bothers you, I'd suggest asking PCS directly. I don't believe any of the PCS motherboards has the header you'd need.
COOLERMASTER MASTERBOX MB540 ARGB GAMING CASE
ASUSĀ® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
CORSAIR 850W RMx SERIESā„¢ MODULAR 80 PLUSĀ® GOLD, ULTRA QUIET
WIRELESS INTELĀ® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
FREE 30 Day Trial of Microsoft 365Ā® (Operating System Required)
MicrosoftĀ® Edge (Windows 10 Only)
Standard Build - Approximately 21 to 23 working days
Price: Ā£2,165.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/709ZaKQEj5/
NB that if you did decide the 3060 Ti wasn't going to be enough (which I doubt but look at some benchmarks online for the games you'll be playing), you could get the 3080 and get it under Ā£2500 by going slightly less overkill on the storage solution.
Literally exactly the same as I was going to recommend but the spec didnt copy properly :( was mixed in with a diff spec
I took a look at what you guessed up and changed it to this
ASUSĀ® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
1TB INTELĀ® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW)
CORSAIR 1000W RMx SERIESā„¢ MODULAR 80 PLUSĀ® GOLD, ULTRA QUIET
NOT REQUIRED
Firefoxā„¢
Price: Ā£2,031.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/NS0e6Hs7MP/
NOT REQUIRED
Firefoxā„¢
Price: Ā£1,954.00 including VAT and Delivery
The LIAN LI LANCOOL 215 GAMING CASE has same airflow performance as the 500m a Ā£179 case absolute bargain but most concede the 5000x is better overall
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/7xsYVSq8mu/
With a 3070 if stock was available was my shout
