First gaming desktop
Acerakis
I wanted to buy my first gaming desktop, but I am just completely lost on where to even begin. I'm afraid of posting on the actual desktop help sections as they suggest you need to already have a good idea of what you are looking for, but I don't. I have no idea how to decide what I am supposed to be aiming for. I tried to just looking at the PCs by game section, but it's still completely over my head as to what those lists of parts would actually translate to how it would look.
Sorry, I am probably still posting this in the wrong section.
Ekans2011
There is no reason to be afraid; there are plenty of wonderful people here. ;)
Please look into this and provide the essential details to receive the best advise for your needs.
Acerakis
Hello, I was hoping to buy my first gaming desktop but was feeling a bit lost. I will try to answer the required questions. I'm really not tech-savvy, so sorry for any mistakes I make.
Monitor: Well, I think the easiest option might be if just kept on with the TV that is already in my gaming setup. It is 1080p and correction: 60hz apparently.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32w5500/specifications
I would be open to getting a new monitor and budget wise spending up to £300.
Uses: Primarily gaming. This is where I am most lost on what I should actually be aiming for. I feel like bare minimum, I would be wanting something at least on par with my PS5. Would be used for other general household desktop stuff, but I doubt that is a major factor.
Budget: I think I would probably be aiming for something around £2000 but could go up to £3000 total including stuff like a new monitor.
So I had initially been looking at the 3 options listed as tailored for Cyberpunk 2077, as putting things in terms of how good that would look compared to it on my PS5 I might understand.
£1570 https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/9UY3w3sJcb/
£1911 https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/vcPKSyPP9T/
£2258 https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/vxcYFEvBTx/
So would the cheapest of the three, or something similar, be suitable if I was expecting something on par with my PS5 and continuing with my current 1080p/100hz tv? Or am I completely off the mark and that is notably better/worse than PS5.
One thing I was unsure of, all 3 had the wifi card set as NOT REQUIRED. Is that because it already has wifi from another component or because the expectation is stuff should be cabled for gaming? Because when we upgraded to fibre broadband, there were no ethernet ports on the hub, and we were told everything was just wifi these days, which I was dubious of but not really in a position to argue as it didn't come up until it had already been installed. I don't really play multiplayer games, so wifi only would be acceptable to me.
Thank you for your help.
Acerakis
I posted.
Monitor: Well, I think the easiest option might be if just kept on with the TV that is already in my gaming setup. It is 1080p and 100hz I believe.
That’s a 60Hz TV, it’s only high end OLEDs some of which are 120hz and normally only on 4k, other than that they’re all 60hz.
Ir wouldn’t be considered suitable for gaming as you’d be limited to 60fps at 1080p which is really poor these days, maybe 20 years ago
But with your budget you could get a top end ultrawide system including a monitor which would be a really rich experience
PCS really need to either get rid of those game-focused recommendations, or actually get them right...as neither of the AMD options is the optimal choice for gaming (that would be the 7800X3D).
PCS are probably going by the 'system requirements' that the game publisher releases, and then thinking xxx= 6 cores, so the yyy with 12 cores will be twice as fast.
If you're sticking to that 60Hz 1080p TV (the 100Hz marketing schpiel is just software doing frame insertion to make it smoother), then you stick to the lowest budget and get a 1080p AMD build for £1500-£1600.
If you're happy to spend £2000 on the PC, then we can go up to 1440p - assuming you're happy to go out and spend on a decent 1440p monitor.
Acerakis
Does seem like a new monitor would be best then. Think for simplicity's sake, I would want one with speakers in it, so I can still use it for my PS5 and switch easily if possible.
Monitor speakers are dire, best avoided, they're like 2 or 5 watt so sound attrocious.
That's aside from the fact that there are very few gaming monitors that include speakers for this exact reason.
An external pair of speakers would be a better option.
If you're going with 1440p, I'd highly recommend this monitor, it's an absolute steal at around £300, but be quick, these are insanely popular and will sell out fast
Forgive my ignorance, but what’s so special about this VA version over the cheaper IPS version…is it the mini-LED backlighting & proper HDR?
Acerakis
Okay, so if I am getting a new monitor, and it sounded like three builds I posted first are wrong then I am not really sure what to be looking for in a build. In deals, I saw this, hope the link works okay as there didn't seem to be the usual 'post to forum' option for deals.
Or does anything else in deals look good? At least as a starting point to figure out what I am looking for.
Ekans2011
Given a total budget of £3000, here is the top-tier build I would go to play in 1440p. :)
I would avoid pre-assemblies, which are often poorly designed platforms.
ASUS® TUF GAMING X670E-PLUS WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
16GB NVIDIA GEFORCE RTX 4070 Ti SUPER - HDMI, DP, LHR
Graphics Card Support Bracket
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR ICUE LINK H115i RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Firefox™
Price: £2,453.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/ThztJyNDfH/
Above is exactly what I would have recommended, the only slight thing for aesthetics that I would consider would be the H150i over the H115i. This is because the H150i is 360mm and has the same looking 3 fan setup as the case itself.
Paired with a good monitor and a small set of speakers it would be an epic gaming build. You'll notice the difference with your PS5 on that monitor as well.
