Firefox Problem: Amazon boxes not showing up?
jonbam
Hi
In IE you can see the boxes with the memory options.
But if I try to view in firefox the boxes do not show up?
I had the same problem on another computer, a laptop and I fixed it by doing the following:
The above solution does not work on my desktop computer.
Chrome & IE work fine on my desktop computer.
But Chrome & IE on my laptop are not working?
Any help
thanks
Jonathan
Are you sure it's not an add-on? I can see a blue dot with a 2 by it on the bar at the top of the FF image, what's that? Try disabling add-ons and see if it still happens?
Rakk
The Awesome
Using Firefox (version 36.0.4) at work I can see the boxes to click on to select size and whether you want Special Offers or whatnot on the lock screen
I don't see those storage selection boxes on either E11 or a Chromium-based browser (from Comodo).
jonbam
Hi
Update: I checked the Amazon URL at 8.51pm today 31-3-15 and the problem has been fixed. I think it may of been a coding error at Amazon and not a firefox error?
thanks
Jonathan
Wozza63
Biblical Poster
You might have had a hotfix installed to your Firefox browser without you knowing. But most likely an error in the website code on Amazon's part. Web development is a pain in the backside having to make it work with loads of different browsers that never just play nice with each other.
