Hi Everyone,
I am planning to build a new system, and I could use some help deciding the final build.
A couple of days ago the Ryzen-based configuration page showed the Corsair 3200MHz rams, but now I can only select the 3000MHz ones. This link says the 3200MHz kit is compatible with the selected motherboard:
http://dlcdnet.asus.com/pub/ASUS/mb/SocketAM4/STRIX_B350-F_GAMING/ROG_STRIX_B350-F_GAMING_Memory_QVL_20170519.pdf?_ga=2.205582353.329936003.1496830631-1995554391.1496830631
Here are my questions:
1. Based on the below configuration, do you think it is a good idea to go with the 2x8Gb 3000MHz Corsair kit, or shall I ask to change it to 2x8Gb 3200MHz kit (if it is even possible, after all, they are not shown for that configuration)?
2. As I am not overclocking my system and will only use it in full HD resolution (1920x1080), do you think I need custom CPU cooler, or the stock one would be enough? I only play maximum of 1.5-2 hours or even less, so I am not that hardcore gamer, however as I am an (hobby) indie game developer, I am using Unity and also I am playing music using Cubase.
3. The customization page does not state the brand of the video cards, it only says 6GB GTX 1060. Do you know which one it is? I guess Palit or Zotac, but there are multiple different cards from them, too (Mini, Jetstream, Super Jetstream, ...). I am just curious, I know the performance will more-or-less the same of all cards.
AMD Ryzen 5 2600 Six Core CPU (3.4GHz-3.9GHz/19MB CACHE/AM4)
ASUS® STRIX B350-F GAMING (DDR4, USB 3.0, 6Gb/s) - RGB Ready!
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler
Thanks for all the help!
