Final Spec Check
Nafninja23
Hey,
Thanks to a couple of the mods I've managed to get a spec which I think will be best for me. This price is really the most I can go as it will allow me to get a monitor.
My only question is about the mobo. Is it worth getting the next one up, this would mean however, I would probably go for the slightly cheaper Maelstrom T900 case. Or will my current selections be fine?
Thanks all :)
Spec...
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5-2400 Quad Core (3.10GHz, 6MB Cache) + HD Graphics
ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
2GB AMD RADEON™ HD6950 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£16) (might get Home plugs)
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£139)
DVI-D & HDMI Monitor Cables
1 x 2 METRE DVI-D CABLE (£5)
Nafninja23
Ok awesome thanks a lot. (I have bump processor up to i5-2500). But if all looks good I'll hopefully be able to order tonight, or at least ASAP :)
Wozza63
Biblical Poster
you should be getting a message saying that the iiyama is supplied with a DVI-D cable, so you can save yourself a fiver there unless you need it for another monitor
and it looks very good, good move on getting the 2500 as well
Nafninja23
Cool, i'll minus the cable then, thanks for the tip.
I'll probably go for the wireless card, and buy homeplugs separate due to not knowing what to expect at uni next year.
I assume that'll work :p
Wozza63
Biblical Poster
afaik uni is most likely going to be a wired ethernet connection, thats what both of my sisters have
