Final question before ordering 17.3'' Optimus III
Dizmo
Is there any reason I wouldn't want to upgrade from the 48.84WH to the 62.16WH battery? I'm assuming it's the same size and would equate to 27% extra battery life.
The specs I'm thinking of going with are:
Quad core i7 3610QM CPU
4GB of RAM
Scorpio 750gb 7200RPM HDD
No operating system
62.16WH battery
£726
Guess not much can go wrong with that. Maybe I'll go with 8GB RAM, though.
tom6561
Looks pretty balanced to me, you could always put in extra RAM later, 4GB is good for now but 8GB would be more futureproof if you don't want to play with it. The battery could possibly be a bit bigger and stick out a bit, have to see what PCS say or anybody else that knows.
Dizmo
Hmm, realistically I'll never use it on the move so £39 for the extra battery life might not be worth it, so I'll probably go with the 48.84WH one, but will wait till tomorrow for a response on the size before making my mind up completely. :) Decided I'll get 8GB RAM just in case, I seem to be using 3GB or so lately.
EDIT: Ordered! :)
