Final Check Before Buying
Dr_Turkeltin
Anyone have any thoughts or comments on this build before I buy?
The case is Fractal Design Focus G.
Monitor: ASUS TUF VG32VQ (144hz, 1440p & HDR).
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
LED Lighting
50cm White LED Strip
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/NXZ!mH9HNx/
Dr_Turkeltin
They have not it will still be specifically for gaming and I'd prefer not to go much higher with the budget if possible unless it's essential or worth it. I'm happy with the build, it was just looking to see if I had overlooked anything and hear some thoughts.
No I am sending in the case thankfully.
My bad didn't realise I had left it out. I will thanks.
Dr_Turkeltin
It's really not I know I could save a lot on the CPU as even any of Ryzen 5 would do well with any of the new TW releases. But I'd just like to future proof while I'm actually buying.
Oh I didn't know that about the 3900 series, I will definitely change to that motherboard then! As for the SSD makes more sense to use the Samsung as well thanks.
Appreciate the advise thanks.
