Final build (hopefully)
paddyc
Well im finally ready to order after about 2 months of building and rebuilding, tbh im very happy i waited since more components are available. Anyway I just wanted to know what you all think and if you can suggest any better build for around the same price (around £1300). Overall I really want a decent laptop that is good value for money hence no SSD.
I'm planning to use this laptop to take to uni every day and to run software like autocad and maybe a little flight simulator if I get time. I also use ftp quite allot so I would prefer a decent network card.
Vortex II: 15.6" Glossy Full HD LED 16:9 Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-2720QM (2.20GHz) 6MB Cache
8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 4GB)
2GB AMD® Radeon® HD 6970 - DirectX® 11 (15.6" Vortex II)
Memory - Hard Disk
500GB SEAGATE MOMENTUS XT HYBRID, SATA 3 Gb/s, 32MB CACHE (7200 rpm)
Bluetooth & Wireless
GIGABIT LAN & INTEL® CENTRINO® ULTIMATE-N 6300 WIRELESS upto 450Mbps
2 x USB 3.0 PORTS + 2 x USB 2.0 PORTS AS STANDARD
Vortex Series 8 Cell Lithium Ion Battery (3,800 mAh)
Power Lead & Adaptor
1 x UK Power Lead & 180W AC Adaptor
Notebook Mouse
And i know its early days but i was wondering if anyone has a laptop with the amd 6970 gpu, if so have there been any problems? I know theres a bit of a mess going on with this card causing fatal problems but what do you guys think pcs will do if I order this spec and theres a problem and they remove this gpu, will I get a new laptop with the gtx 460 and some money back or will I be able to completely change the spec to match the cost?
Thanks in advance
PCS
Administrator
Staff member
Great spec you've put together there which will be more than capable for autocad and Flight Sim! :)
You can keep track of 6970 developments here: http://www.pcspecialist.co.uk/forums/showthread.php?6912-6970M-Fail
If (and that's a a big IF) your 6970M should fail, you will be fully covered under warranty. You will be able to select a different GPU and if it's cheaper we will credit you the difference.
paddyc
Thanks for the feedback lads
I think I will check whats happening gpu and providing theres no problems the order will be placed first thing on monday
Littletruck
Did you get this ordered? Hows it running....
I am looking for a new laptop to run Autocad 2009 alongside photoshop & dreamweaver CS4 as my old Toshiba is on its last legs :( but haven't got a clue where to start.
