Final advice and/or critiques on build before I go for it!
Del.
**Edit - Added full written list as well as image of list
*Edit - Now with required info as directed by mod - Apologies I did not include to begin with!
Config link https://www.pcspecialist.co.uk/saved-configurations/amd-am5-sff-gaming/DjGBeRXZru/
Monitor - Alienware aw3420dw
Max Refresh Rate - 120 Hz
Size - 34"
Pixel Type - IPS
Native Resolution - 3440 x 1440
Variable Refresh Rate - G-SYNC
Max budget - Was aiming for the £2k mark, so already over...but could be convinced to spend (a bit) more if the reasoning is logical/valid
Hi - I am finally ready to pull trigger on my machine build. Have done as much research as I can and believe I have found the right config between a working machine for 3D Printing projects, Video Editing, home labs, and a solid gaming machine that can give me the 'PC Gaming' experience of high quality/ray tracing and high fps.
Here is the spec for my build - Should be noted I'm going for a 'higher end' build because this has been a saved tab on my phone for nearly two years and I'm treating myself, I am aware that I could reduce cost and performance to get the same sort of results for my needs...but, shiny things:
- Thermaltake tower 200 vertical gaming tower case - I have a specific space and this fits perfectly, prefer 'tower' type set ups too
- AMD Ryzen 9 7900 12 core processor - Looked at the 7900x but the stock 7900 is better power consumption, less heat production, and can overclock to 4.7/5.0GHz from 4.0/3.7GHz (haven't decided yet, was going to play and test)
- ASUS ROG STRIX B650-I motherboard - Best of the two options made available to me through builder
- Corsair vengeance 32GB RAM RGB 5600MHz 2 X 16GB - Feel like this should be sufficient...Happy to be proven/told I'm wrong though
- 12GB MSI RTX 4070 VENTUS GDDR6 - Was going to go for the RTX 4060TI but after further consideration/research, the 4070 out performs it to such a degree it warrants the upgrade for this build, and upgrading to the 4070 (relatively) doesn't add that much more to overall price
- 1TB Corsair Elite MP600 SSD - Where OS and main applications will be hosted
- 2TB Corsair Core XT MP600 SSD - For gaming and complex files
- 2 X 2TB Seagate Barracuda HDD - Storage for everything else and potential back up drive
- Corsair 650W RM Series PSU - Suggested a 550w but this seems to be the better option, and is quieter
- Corsair H100x CPU Cooler - Planning to overclock the CPU so seems logical to have a decent CPU cooling system
- Arctic MX-4 Thermal Paste (on CPU) - Because sensible
- 4 x Corsair RS120 ARGB fans - Because they light up, and do some cooling I guess
THERMALTAKE TOWER 200 VERTICAL GAMING CASE
AMD Ryzen 9 7900 12 Core CPU (4.0GHz-5.4GHz/76MB CACHE/AM5)
ASUS® ROG STRIX B650E-I GAMING WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
32GB Corsair VENGEANCE RGB DDR5 5600MHz (2 x 16GB)
12GB MSI GEFORCE RTX 4070 VENTUS 2X E1 12G OC GDDR6 - HDMI, 3 x DP
1TB CORSAIR ELITE MP600 NVMe PCIe M.2 SSD (up to 7000 MB/R, 6200 MB/W)
CORSAIR H100x RGB ELITE HIGH PERFORMANCE CPU COOLER
LED Lighting
50cm ARGB LED Strip
4 x Corsair RS120 ARGB PWM Fan
ONBOARD Wi-Fi 6E
Price: £2,162.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-sff-gaming/KDAesHBZtc/
Let me know what you think!
Del.
Hi can you include the full spec from your order page including the configurable link? Also let us know the budget for the pc. Most common questions are here: https://www.pcspecialist.co.uk/foru...posting-collaboration-of-helpful-hints.77691/
First thought from me is that there's no need for the Arctic thermal paste if going for the Corsair AIOs the thermal paste that's pre-applied to the AIOs is mighty enough :)
Ahh apologies I have updated my original post now 👍
Del.
Image of specs in the post and listed items and reasoning also a text updated along with the config link - Have copied spec again and posted below:
LED Lighting
50cm ARGB LED Strip
ONBOARD Wi-Fi 6E
Del.
Size - 34"
Pixel Type - IPS
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB)
LED Lighting
50cm ARGB LED Strip
3 x Corsair RS120 ARGB PWM Fan
ONBOARD Wi-Fi 6E
Price: £2,163.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-sff-gaming/srkFxtQU5h/
Del.
Believe I have found the right config between a working machine for 3D Printing projects, Video Editing, home labs, and a solid gaming machine that can give me the 'PC Gaming' experience of high quality/ray tracing and/or high fps.
Here is the spec for my build above - Should be noted I'm going for a 'higher end' build because this has been a saved tab on my phone for nearly two years and I'm treating myself, I am aware that I could reduce cost and performance to get the same sort of results for my needs.
Del.
Sorry to pester I really want to buy before the xmas cut off, please are you able to help?
