Feedback on specs
Slysay2
Hey Guys so Ive been looking at these specs and im planning to use it for gaming such as COD RDR2 etc and was wondering if this is good at all?
PCS SR-628B RGB GAMING CASE
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
512GB INTEL® 660p M.2 NVMe PCIe SSD (upto 1500MB/sR | 1000MB/sW)
STANDARD AMD CPU COOLER
LED Lighting
50cm RGB LED Strip
Welcome Book
Logo Branding
PCSpecialist Logo
andjac
Theres a few things you're going to want to change!
Monitor, what are you going to be pairing this with. Either model number or resolution and refresh rate?
Budget, what's your ideal spend and max spend?
If you can answer these an expert will likely get back to you with some guidance when they can
In the meantime worth you giving this a read:
