Feedback / Advice Before Ordering
lukeirelan-hill195
Good evening,
I have been a follower of this forum for a long while and am hoping you can help with some feedback / advice on the below spec. Laptop will be used for gaming (Football Manager 2018, Sims, City Skylines, GTAV, Witcher 3 (if possible))
All feedback welcome and I look forward to receiving it.
Proteus Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™ i7 Quad Core Processor 7700HQ (2.8GHz, 3.8GHz Turbo)
16GB Corsair 2133MHz SODIMM DDR4 (1 x 16GB)
NVIDIA® GeForce® GTX 1070 - 8.0GB GDDR5 Video RAM - DirectX® 12.1
1st Hard Disk
1TB SEAGATE FIRECUDA 2.5" SSHD - UP TO 5X FASTER THAN HDD!
M.2 SSD Drive
256GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3100MB/R, 1400MB/W)
AC Adaptor
1 x Proteus Series 230W AC Adaptor
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® AC-8260 (867Mbps, 802.11AC) + BT 4.2
3 x USB 3.0 PORTS + 1 x USB 3.1 Type C PORT AS STANDARD
Proteus V Series Lithium Ion Battery (7180mAh)
PROTEUS SERIES RGB BACKLIT UK KEYBOARD WITH NUMBER PAD
Microsoft® Office 365 Personal (12 Month Subscription - Digital Key)
Notebook Mouse
INTEGRATED 720P 30 FPS HD WEBCAM
Dead Pixel Guarantee
Price £1,495.00 including VAT and delivery
Looks good and should perform well in all of those titles.
You might get the 2400MHz RAM if the price difference is modest. FM likes faster RAM from what I have seen.
You should check out Open Office, which is a free and open source office package. It actually has more software than just the basic MS Office packages, and is compatible with common formats like .doc, .xls etc.
lukeirelan-hill195
Hi Oussebon,
Thanks for the quick response and feedback.
They do not seem to offer the Consair Vengeance 2400 as an option on the Proteus 15.6 build.
They do have it with the Defiance 17.3 build. How much difference do you think it will make, as I could get the same spec as above but on the Defiance 17.3
I await your feedback.
Thank you.
Even for FM the difference going from 2133MHz to 2400MHz would be relatively small. Probably worth it for a few quid but I wouldn't buy a much more expensive chassis over it (and the Defiance is quite a bit more expensive I think?)
Tony1044
I give a cautious thumbs up to LibreOffice - especially now you can optionally enable a ribbon bar to make it look more Office 2007+ like.
However I say cautious as it's fine for the odd document here and there but if you work with anyone sending you Office docs on a regular basis (especially things like macro enabled Excel files or fancy Word documents) you may find it struggles with compatibility.
I mean, even versions of Office can struggle with inter-compatibility so...
