Fan Placement/Direction
Simo/V
I have recently purchased a desktop Pc from PcSpecialists, with the NZXT M59 gaming case. I am about to overclock my cpu after adding a new cpu fan (Akasa AK-CC4008HP01 Venom Voodoo) and several case fans (Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan)
My question is which direction do I place the case fans (drawing air into the case or out of it) and where do i plug them into the MB?
Thankyou for your time, Simon.
NMEBowen
Master Poster
you should evenly distribute intakes and exausts allowing cold air in and hot air out the fans should be fitted to the corasponding plugs and sockets on the motherboard you shouldnt be able to plug them into anything else so its pretty straight forward they should also be labled fan 1 etc.
