blackhawk
I powered up my new pc and found that the rear fan was not working. the top and side fans are ok I disconnected the top fan and connected the rear fan into its cable to see if it was a faulty connection on the motherboard but still did not work i can only assume the fan is faulty
would i still be able to use pc or would you wait for another fan dont want it to overheat, not gaming on it at the moment
