No program can control the family mate (fams) sorry it made me Laugh!Can anyone recommend a good (preferably free) program to control the fams - am finding they get quite loud during gameplay - My spec is in the signature
You’ll want Fan Xpert 4 which is part of Asus AI Suite 3 for your case fans, and iCue will take care of your cooler.Can anyone recommend a good (preferably free) program to control the fams - am finding they get quite loud during gameplay - My spec is in the signature
Sorry bud! Hope you got it sorted!Thanks @AgentCooper, and as for you @SiAdams, why I oughta.....
have you tried setting any custom curves and applying themweirdly, since installing and running Fan Xpert 4 and setting it all to silent, the thing is now permanently locked on to noisy mode whether I am playing or not, will have to uninstall I think
Odd that Fan Xpert didn’t work for you. Another way to create a fan curve to suit is via the BIOS, although it’s a bit more fiddly.Seems much happier now I have uninstalled Fan Xpert, and while I was at it I uninstalled Armoury Crate and have to say my boot up speed has noticeably improved
