I have a 5900x on a ROG STRIX X570 motherboard in a 500D SE case, with a H115i Platinum AIO. There is also a 3060TI in the mix. I am slowly getting the machine set up, installing applications and transferring data from my old PC.
Having never played with fans and pump settings before, I am looking for advice on setting profiles within iCue. Currently, I am just using the stock quiet or balanced profiles. I am not sure what fan / pump speeds I should set and and what temperatures they should change. I will be using the PC for photo editing in Lightroom and Photoshop. I will probably add an exhaust fan (LL120) at a later date, once I have had a chance to look around the internals a bit and find out how the 3 LL120s at the front of the case have been connected. Can someone with experience of this give me some guidance?
