Failing AIO, recommendations for new cooler?
LiaEva
Around two years ago I bought a PC from PC Specialist and this awful sound has just randomly appeared from no where. It sounds like it's coming from the side of the PC, I can't upload a video unfortunately.
Much appreciated
Much appreciated
We'll need a video if possible, if it's too large for the forum, you can upload it to youtube or cloud storage and post a link
Can you post your full specs from the order page as well?
LiaEva
PCS SPECTRUM RGB MID TOWER CASE
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
sck451
Sounds like either a pump failure (which is the part you tapped) or a fan that's blocked, probably the former. My first thought is to think the cooler needs replacing.
LiaEva
Damn, I thought that but I was hoping it wasnt lmao. Thank you :)
B4zookaw
Yeah I think the fan too. The only other noise that comes close would be if a cable is touching off a fan as the fan spins. But that sound is a different tone from what is on your video. You seeing any increase in cpu temps?
LiaEva
Currently idle it's sitting at 31, that's using the AMD Software to monitor it
B4zookaw
Reasonable temp. The pump may be capable of circulating the coolant still, but it's just making a racket. Looks like the pump gets it power from a fan header, see if you can trace the cable from the pump to the motherboard and disconnect it. It will be fine to run it without the pump of a couple of mins at idle, but if the noise disappears when it's disconnected, you've confirmed the pump as being the source.
If it is the pump, you can put in an RMA to get it replace, but personally I'd suggest paying the additional to upgrade it to an H80i which would be far better. Those coolers ended up having a little bit of a reputation
LiaEva
I can feel the coolant still being pumped through the tubing but I'll try what you just mentioned
LiaEva
Is it a possibility it's trapped air, I've seen a few videos and they sound very similar to the noise inside my pump
Can you upload a photo of the cooler and the radiator, so just a view of the inside layout?
Images need to be under 1MB in size to upload
LiaEva
Sure
LiaEva
Should my PC be turned off for this?
B4zookaw
Does the sound occur as soon as PC is switched on? E.g. before it even loads Windows? If so, you can power off PC, disconnect cable, then turn it on. As soon as you confirm noise is not present, kill the power and reconnect. But even if you did it when under power, it won't cause a problem, the CPU won't overheat in just a few mins at idle.
LiaEva
Yeah it's definitely the pump, I disconnected it and the noise has gone
