extra battery life
helly
I have recently purchased an ultranote (specs below).
initially I was happ with battery life but now I find that it's just a little too short for me.
I would like to get a power bank that can charge my laptop so presumably needs ac output (I'm clueless with electricity so bear with me!)
I also don't know if you get something that has a certain wattage will it blow my laptop
also is it possible to charge the laptop via usb-c because if I have to use the cable it kind of defeats the purpose of having a nice compact charger on standby
PCSPECIALIST.CO.UK SPECIFICATION
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
UltraNote Series: 14" Matte Full HD IPS 60 Hz 45% NTSC LED Widescreen (1920x1080)
Intel® Core™ i5 Quad Core Processor i5-10210U (1.6GHz, 4.2GHz Turbo)
8GB Corsair 2133MHz SODIMM DDR4 (2 x 4GB)
INTEL® HD GRAPHICS (CPU Dependant) - 1.7GB Max DDR4 Video RAM - DirectX® 12
1TB ADATA SU800 M.2 2280 (560 MB/R, 520 MB/W)
AC Adaptor
1 x 40W AC Adaptor
UltraNote Series Integrated 36WH Lithium Ion Battery
WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
1 x USB 3.1 PORT (Type C) + 1 x USB 3.1 PORT + 1 x USB 2.0 PORT
ULTRANOTE SERIES UK KEYBOARD
Windows 10 Professional 64 Bit - inc. Single Licence
Firefox™
INTEGRATED 1MP HD WEBCAM
Chassis
Clevo NL41CU FHD (i5-10210U, FHD, 60Hz N4, Blank KB)
Price: £695.00 including VAT and Delivery
helly
found this on ebay but nervous about using. my laptop transformer says 45w input and this can do up to 65w. not sure about whether this is safe but apparently more important to get >= 65w or laptop won't charge
I need to do more research but would welcome any input from anyone who's gone down this route
According to the detailed specification, the USB C port is just a data port, no video or power delivery so you wouldn't be able to charge over USB C
But for a confirmed answer, I would definitely contact PCS, they don't monitor these forums and none of us work for them.
Read the Terms & Conditions, especially this one....
7.8 If you install components that are not purchased from us and they cause problems with your computer, your warranty will be void;
helly
yes I was aware of that. trying to find a solution that converted usb output to ac safely - I have asked PCS - let's see what they say - probably same as people here - don't mess with it!
