No, 4GB is the amount of RAM you have - presuming you went for the spec on page 4 of your original thread here: https://www.pcspecialist.co.uk/forums/showthread.php?25444-Improvements-alternatives-on-this-pleaseI have a tower which has 4GB (if I'm looking at the right measure) and have lost things in the past when the hard drive failed and even when two hard drives were installed, doh - all
See my point above - so for 125 backups of 500GB, that would actually be a shed load of space (62.5TB to be exact), however generally people wouldn't keep nearly that many backups, also you would really only want to back-up data, most backups are just of data (which probably wouldn't really be close to 500GB anyway), and if the drives go then the software is reinstalled and the data is then copied onto the new drive.I think that the penny has dropped about the disparity that if my tower is 4GB, I'd need say 500GB to make 125 back-ups (if all 4GB used). Hopefully that's right.
Thanks tom_gr7. I didn't know the software could be an issue.
I've been following your other thread on auto backup software: https://www.pcspecialist.co.uk/forums/showthread.php?26804-Auto-backup-Software I hope you don't mind me linking it here so I don't lose it![]()
