Ethernet Port Help
adacla526
Hi guys,
I've ordered a PC with a WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD, however I'm just wondering if this, or anywhere else on the PC contains an ethernet port as once I have set up my home network properly, I will be running it through ethernet rather than wireless. If you could help that would be great so I know to change my order back to wired and then buy a wireless adapter separately.
Adam
mantadog
Superhero Level Poster
yeah, you will have a single ethernet port built into the motherboard so just pop the cable in and switch off the wireless in the device manager control pannel to avoid any issues
