Ethernet cable extender?
Jack Guinea
I got my new desk today and my ethernet cable wont stretch to where it is, is there some cable or something i can get like an extension as i cant just get a longer wire as it goes under the carpet.
Wozza63
Biblical Poster
Lol I paid a penny for a 10m ethernet cable but that was on sale, just thought I'd let you know :p
Im sure amazon has them for about a quid, don't worry about quality, I've never had a problem with cheap-o ethernet cables
alexstephenson
HDMI Extender Over Cat 5e/6
The HDMI Extender by Cat5e/Cat6 lets you extend the distance between any HDMI-equipped DVD player, Media Centre PC or Games Console and your TV screen using Cat5 or Cat6 network cable.
The transmitter and receiver are then connected over a longer distance by two lengths of Cat5e cable (or Cat6 cable). One Cat5e cable carries the HDMI DDC signals and the other Cat5e cable carries the HDMI Video and Audio signals.
The HDMI over Cat6 enables an HDMI display to be located up to 30 meters away from the source device.
The HDMI over cat5e extender is perfect for the meeting room, home theater or any installation that needs long distance transmission and superior video quality.
With support for High-Definition resolutions of up to 1920x1080 / 1080p, this HDMI extender can easily be installed using new or existing
What i mean is if i get that and another shorter ethernet cable would it work?
It will work but couplers and connectors introduce the possibility of noise on the Ethernet connection and that's not good for performance. It's way better to get one cable the length you need, even if that means paying that bit extra to have one made up specially.
