All three Cube movies are excellent! Especially for bringing a hypercube which is ultimately quite a difficult concept to the masses (even if only for dramatic purposes )I'd recommend Cube for something similar but also very very different
I didn't know there was more than one to be honest. I'll definitely check out the restAll three Cube movies are excellent! Especially for bringing a hypercube which is ultimately quite a difficult concept to the masses (even if only for dramatic purposes )
Cube (1), Cube 2: Hypercube, Cube: Zero (3) Definitely check them out!I didn't know there was more than one to be honest. I'll definitely check out the rest
Be careful to avoid Borg cubes.Cube (1), Cube 2: Hypercube, Cube: Zero (3) Definitely check them out!
Resistance is futileBe careful to avoid Borg cubes.
I love those, it's really difficult peeling off the stickers so you can put then in the right place though.
