Entry Level Gaming PC
eeperman
Hi all,
Been out of the world of PC gaming for over a decade, but my son is keen to get a desktop gaming PC to replace his asthmatic laptop. We already have a monitor, headphones, mouse and keyboard so this i just a spec for the box to plug them into. Currently he mainly plays Roblox and Minecraft which I imagine aren't too demanding, but I would like the headroom for him to play other games. He also enjoys making and editing gameplay videos to post to YouTube etc. Budget is £600-£700 and I specced the following:
CORSAIR 175R RGB MID TOWER GAMING CASE
AMD Ryzen 3 3100 Quad Core CPU (3.6GHz-3.9GHz/18MB CACHE/AM4)
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
8GB Corsair VENGEANCE DDR4 2400MHz (1 x 8GB)
4GB NVIDIA GEFORCE GTX 1650 SUPER - HDMI
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
PCS FrostFlow 100 V2 Series High Performance CPU Cooler (AMD)
Price: £680.00 including VAT and Delivery
Would this do the trick? I am (and always have been) a bit clueless on RAM - is one stick of 8Gb better than two sticks of 4Gb? Is there any real advantage to going for higher RAM speeds? And how future proof is this motherboard if we want to bump up the CPU or GPU in the future? Finally, I can probably chuck another £20-£30 to the build - where would you spend the money?
Many thanks for your help
CEng
The AMD Ryzen 3 3100 has two memory channels so you should go for two DIMMS as this will give you twice the speed (GB/s) of one DIMM (the CPU will use both in parallel). If going for a SSD better to go for M.2 PCIe as this stops the SSD being limited by the interface to the motherboard. You get more speed 1900MB/R 1100MB/W for -£5. Move up to a 512GB M.2 PCIe SSD for the operating system as it will allow more room for often used applications/games if you can.
