Elimina Series: 15.6" Review
davieb
Had a my laptop for a couple of weeks now.
Overall pretty happy with it.
The case quality is better than my previous PCS Laptop, a bit more robust and the keyboard feels better.(cool led lighting)
Games run great, but the fans are really noisy and, it gets pretty hot.
Hope that wont be an issue further down the road..
2 usb's left side ( 1 on the right would have be better in my opinion for a mouse) had to use the usb c on the back for this.
Power socket for the psu is also on the back next to the vents, where it gets pretty hot.
My previous laptop's power was on the side ,keeping it out of the way.
This would have ben preferable.
OS is fast and snappy, boots up in seconds.
Service was pretty great as always from PCS.
Elimina Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 14 Core Processor 12700H (2.3GHz, 4.7GHz Turbo)
16GB Corsair 3200MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 3060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 180W AC Adaptor
Elimina Series Integrated 54WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 + BT 5.0
2 x USB 3.2 PORTS (Type C) + 1 x USB 3.2 PORT + 1 x USB 2.0 PORT
ELIMINA 15" SERIES MULTI COLOUR BACKLIT UK KEYBOARD
INTEGRATED 1MP HD WEBCAM
Welcome Book
Maurizio
Hi davieb, can I ask you 2 things about the laptop?
I would have to use the laptop for music production, so the GPU would be almost at 0% and the CPU (most of the time) at 50-60% of power...
Does it get loud even when it's not so under stress? Do you know if the cpu or gpu is responsible for making the fans so noisy?
Thank you
