yotoprules
before I decide to buy this laptop, I would like to know a couple of things:
What are the main differences between the standard Elimina and Elimina pro models? I udnerstand the Elimina is a Clevo and the Elimina Pro is a tongfang, but is the tongfang specifically better in any way? Other than battery?
What is the TDP of the RTX 3060 in the Elimina Pro?
And is there a MUX switch?
I'll probably still buy it either way since its way cheaper than competing laptops but knowing whether its a "MAX-Q or MAX-P" equivalent and whether optimus can be bypassed, because I really despise nvidia optimus.
Thanks!
Thanks!
