dvd writers
Wozza63
Biblical Poster
im sure you could, but you'd need to phone PCS, and you are mainlt limited by the amount of SATA ports
mantadog
Superhero Level Poster
You could have that man if you wished very easily. I have room for 4 on my very low end case and i doubt SATA ports would be a limiting factor as you could just get an add on card and use a pci slot on your motherboard. Most motherboards have atleast 6 SATA connections anyway so 4 DVD drives + a couple of HDD's would be fine.
Though as wozza said you can't add more than 2 online, so you would have to call PCS anyway.
sanj
Is it possible to have 3 or 4 dvd writers in one case.
Yes I built one last week as we had a customer who contacted us and had requested that 4 dvd writer's be fitted into his case(CM690)and every single one of this sata's was used as he had a hard drive and his e-sata connected too!It's not to everyone's taste's as the customer did state that he would'nt be using all them all at once so I guess it was more for show!
