Driver For Enigma III 540 WLAN Card??
The driver for the Enigma III 540 STANDARD onboard WLAN card isn't working on Windows 7 Pro 64bit. Is there a link where I can download the correct working driver?
Thanks.
MrShteeeve
What card is it? if you can specify what card it is, by searching 'device manager' in te start menu and select device manager, then expand 'network adapters' and there should be the model of your wireless card there. If you can do that I'll most likely be able to find one for you :)
pr1s0ner
I don't use Windows 7 so I can't vouch for it personally but that is Realteks own software so I would assume it would be the easiest way to sort it
