Driver "02 VGA"
drumks
I'll receiv my new laptop and i downloaded all the drivers.
I just have a question (maybe a stupid one) but in the "02_VGA" i have 2 folder (App & VGA) with two setup.exe.
Which one i have to use ?
13460
I guess one is installing the driver + geforce experience, the other one just the driver ?
Did you order the laptop with windows?
If so it should have all drivers installed part from graphics management which you should download direct from nvidia.
If you’re installing your own windows, allow windows update to install all drivers and then manually install graphics from nvidia and the control center/Hotkey/Game Center from your PCS account.
drumks
I ordered it without Windows and i'll do a clean Windows install if it come with Windows installed :)
Thank you for your answer, i'll let Windows update doing his job, but for the nvidia's driver which folder i have to use ?
You dont, you download from nvidia
I would not trust a testing system if you didn't buy it with Windows. A clean install is the best way to be certain you have a good clean system. When you do that run Windows Update until no more updates are found and that will install all the required drivers, well except for anything that's obscure.
It's unlikely to be the VGA folder, I'd expect that to be the iGPU driver.
