ive just finished reinstalling windows 7 after i deleted everything and started again because of a problem but now for some reason my second hard drive isnt showing up, how do i fix this?
Check in disk management to see if the drive/partition is showing there,
click "Start"/right click"computer"/Manage/under "Storage"select "Disk Management",
or click "start" and type diskmgmt.msc in search box.
It's possible you only need to assign a Drive letter,If no letter is assigned for the drive,
right click on the bar of the drive in the lower half of the screen,
select "change drive letter and paths"
click on the Add button in the next menu to select a drive letter.
Click ok to assign selected drive letter or choose your own letter from the drop down menu.
If the drive is showing as unallocated,
right click on the black bar of the "unallocated drive",
click on "new simple volume"then follow the wizard.(this will delete all data)
check in "computer" to confirm missing drive is showing.
