Sorry about the stupidity of the question but just so I know.
An email from PCS tells me that
"Most importantly, after turning on your computer for the first time you MUST NOT turn off the power to your computer until the initial Windows setup has completed. This normally takes less than five minutes to complete. If your computer is re-started or turned off during this configuration procedure there is a risk that the setup will fail, and this could result in your computer failing to run Windows, with the only available solution being a full re-installation of your operating system."
My question is does this initial set up require access to the internet?
I am asking because my new machine will not have an internal wireless card fitted as I am going to use an existing USB device and I am assuming I will not be able to install the relevant software for that until the windows set up is complete.
Thank you for any help you can offer.
Mick
Mick
