It depends on the build, but most, if not all motherboards PCS use have at least one rear USB-C port.
That being said, I wouldn’t recommend a ready to ship build for the same reason I don’t recommend an off the shelf prebuilt. Such products tend to cheap out on important components like case, power supply and cooling to keep costs down. One of the big reasons to buy from PCS is that you can pick out each individual component and put together a well balanced build, and as a bonus there are some very knowledgeable people on the forums who are kind enough to share their advice if you ask for it!
LIAN LI LANCOOL II GAMING CASE Processor (CPU)
Intel® Core™ i5 Six Core Processor i5-12400F (2.5GHz) 18MB Cache Motherboard
ASUS® PRIME B660-PLUS D4 (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! Memory (RAM)
16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB) Graphics Card
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR 1st M.2 SSD Drive
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW) Power Supply
CORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET Power Cable
1 x 1.5 Metre UK Power Cable (Kettle Lead) Processor Cooling
PCS FrostFlow 120 Series ARGB High Performance Liquid Cooler Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) Network Card
10/100/1000 GIGABIT LAN PORT Wireless Network Card
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 USB/Thunderbolt Options
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS Operating System
Windows 11 Home 64 Bit - inc. Single Licence [KK3-00027] Operating System Language
United Kingdom - English Language Windows Recovery Media
Windows 10/11 Multi-Language Recovery Image - Unlimited Downloads from Online Account Office Software
FREE 30 Day Trial of Microsoft 365® (Operating System Required) Anti-Virus
NO ANTI-VIRUS SOFTWARE Browser
Microsoft® Edge Warranty
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Delivery
2 - 3 DAY DELIVERY TO REPUBLIC OF IRELAND Build Time
Price: €1,740.00 including VAT and Delivery
I would prop up certain areas but I would consider the monitor and uses. What are you using the system for? Is it purely for gaming? The CPU is a great choice for gaming but if you want to stream etc then you'll likely want to look at something a bit more beefy. For purely gaming it's spot on though.
With the GPU, you need to align that to the monitor. If you're looking at 1440p then it's a great choice, if you're looking at 1080p though the 2060 is a more sensible option.
ASUS® TUF GAMING B660-PLUS WIFI D4: ATX, LGA1700, USB 3.2, SATA 6GBs - ARGB Ready Memory (RAM)
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) 1st M.2 SSD Drive
1TB CORSAIR FORCE MP600 NVMe PCIe M.2 SSD (up to 4950 MB/R, 4000 MB/W) Power Supply
CORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Power Cable
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler Thermal Paste
10/100/1000 GIGABIT LAN PORT USB/Thunderbolt Options
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS Operating System
Windows 11 Home 64 Bit - inc. Single Licence [KUK-00003] Operating System Language
Price: €1,960.00 including VAT and Delivery
Hi, still looking at this, price down a little, can I ask why the CORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS was not good enough? Any other views, on the above spec I am settling on 144hz 1440p monitor - possibly either
iiyama G-Master GB2760QSU-B1 27 Inch 144hz
COOLERMASTER GM27-FQS ARGB 27" 165hz
But any suggestions welcome, I can't really go over budget so can't overdo the monitor, but don't want rubbish either!
with thanks to Mr Wilson in the Desktop thread a few weeks ago, I realise this is more the category for asking for final comments, which would be appreciated.
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
www.pcspecialist.co.uk
LIAN LI LANCOOL II GAMING CASE (Special Offer)
Get Warhammer 40K: Darktide with select GeForce RTX 30 Series GPUs!
2nd M.2 SSD Drive
Q. Could I replace the power supply in the list with CORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS without any issues?
Want to pair with a 1440p 144hz monitor - possibly either
All views appreciated, especially downgrades that would save a few quid without rendering it not a good gaming machine, as it's a bit over budget, for a 16 yr old that has simply said "get me a pc that's great for gaming with loads of fps" !!
Eeked out some savings below. The PSU isn't somewhere I would skimp to be honest. You're going to seriously limit yourself. The RMx is a good level of PSU, excellent warranty etc and a very high standard. It's worth it. I would actually consider the 850w or even the 1000w PSU for future GPU upgrades.
FRACTAL FOCUS G BLACK GAMING CASE (Window) Processor (CPU)
1TB PCS PCIe M.2 SSD (3300 MB/R, 2900 MB/W) Power Supply
PCS FrostFlow 150 Series High Performance CPU Cooler Thermal Paste
Price: €1,805.00 including VAT and Delivery
AMD Ryzen 5 5600 Six Core CPU (3.5GHz-4.4GHz/35MB CACHE/AM4) Motherboard
ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! Memory (RAM)
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Power Cable
1 x 1.5 Metre UK Power Cable (Kettle Lead, 1.0mm Core) Processor Cooling
Price: €1,707.00 including VAT and Delivery
Hi all, think i have finalised. Went for Coolermaster monitor (did not want curved and dell not available). Upped to 32gb ram - excessive? Went for Lancool 2 case. Added a keyboard/mouse item.
Appreciate any final comments on this! Thank you.
32GB Corsair VENGEANCE DDR4 3200MHz (2 x 16GB) Graphics Card
Google Chrome™ Monitor
Coolermaster GM27-FQS ARGB 27" - 2560 x 1440, 1MS, 165Hz Keyboard & Mouse
ASUS TUF K1 Gaming Keyboard & M3 Mouse Bundle Warranty
Standard Build - Approximately 8 to 10 working days Promotional Item
Price: €0.00 including VAT and Delivery
