Do monitors come with cables? AOC 21.5" WIDESCREEN LED TFT - 1920 x 1080, 5MS, DVI
J_T_
I'm buying the monitor AOC 21.5" WIDESCREEN LED TFT - 1920 x 1080, 5MS, D-Sub, DVI-D (£89) along with my computer and I was wondering if all monitors on PCS come with a DVI cable? The monitor listed above is DVI compatible so would it come with a DVI cable? It would make sense if it did otherwise I'd have to pay more money just for a cable when I'm already buying a monitor.
It should come, the configurator will give you a warning if you require a cable. You could just stick to your original thread rather than creating others if you have further queries, probably faster for you to post as well.
vanthus
Member Resting in Peace
The monitor you selected comes supplied with a DVI-D cable.
