CorneredTiger
It's been around 2 weeks since I received my PC and noticed that I've been having disconnects with the Bluetooth when playing games. Once the disconnect happens, I can't connect to my Bluetooth speaker and a yellow bang is shown on device manager for my Bluetooth speaker. When trying to uninstall the device, the dialog appears but never seems to finish. I then do a restart but during the restart progress (the blue screen with restart text after clicking on the restart icons on windows), It never restarts and instead shows a BSOD with Driver Power state failure stop code. No driver specially was mentioned on the BSOD.
This has happened 3 times now and was wondering if this was due to the intel AX200 WIFI+BT 5.0 card.
What I've tried:
Uninstalled the Bluetooth driver via device manager (as well as clicking on the checkbox that appears when uninstalling it), reinstalled the driver via intel website. Still having the same issue.
I've attached the Memory dump. Seems to be the Bluetooth mini support driver (BTHUSB.sys which appeared on the events tab on device manager for the Intel Bluetooth card) but want you all to confirm first.
Full spec can be found below:
COOLERMASTER MASTERCASE H500M GAMING CASE
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
1TB INTEL® 665p M.2 NVMe PCIe SSD (up to 2000MB/sR | 1925MB/sW)
STANDARD AMD CPU COOLER
What I've tried:
