Different Air CPU Fan Request
Stuj
Hi
I have been unable to get hold of PCS because no doubt they must be very busy with the increased demand with the work at home etc.
A couple of questions if anyone is able to help that would be great.
1, Can PCS supply and fit an alternative CPU fan that they are not listing on the PC builder part of the website.
The one i would like is:- Noctua NH-D15 chromax.black CPU Cooler (black)
The one PCS list is Noctua NH-U14S Ultra Quiet Performance CPU Cooler (horrid brown colour)
Yep, I know its just a colour that I don't like but really want this computer to look the part. (scared of going for a AIO as we leave the computer on 24x7)
2, Advise on the spec I have chosen so far (use the computer all day long for work, photoshop, video editing etc.) and light gaming.
TIA
Stu
CaseCORSAIR OBSIDIAN SERIES™ 500D SE CASE
Processor (CPU)AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
MotherboardASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB)
Graphics Card6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
1st Storage Drive2TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
Partitions: 1000GB, 1000GB
2nd Storage Drive6TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
Partitions: 6000GB
1st M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
Partitions: 500GB
2nd M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingNoctua NH-U14S Ultra Quiet Performance CPU Cooler
LED LightingNONE
Extra Case FansNONE
Wireless Network CardNONE
Operating SystemWindows 10 Professional 64 Bit - inc. Single Licence
Anti-VirusNorton 360 Deluxe: 1 User, 5 Devices - 1 Year Subscription
BrowserGoogle Chrome™
Build TimeStandard Build - Approximately 21 to 23 working days
Gavras
Master Poster
Most likely not, (I would imagine..) from a business and warranty point of view it would be a pain.
Can you include link to your build.
Also a lot comes down to what is your budget, what the PC will be used for and monitor graphics card will be paired with.
Stuj
Final Spec
Corsair H115i RGB PRO XT Hydro Series High Performance CPU Cooler
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/G0vju94NHq/
Final Spec
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/G0vju94NHq/a
Save yourself some money and Drop the thermal paste as the cooler comes with high grade paste already and drop Norton. Windows defender is good enough nowadays :)
Stuj
As above though, budget, what you using it for , what monitor
I need to get two new monitors but will do that later.
both me and mrs work full time from home like many others now so we need a decent computer for photo and video editing. Im not much of a gamer but thought may as well get a pc that's capable to get into it.
One last questions.
When the computer goes into sleep, can you programme the fans and water pump and rgb lights to all turn off?
Stuj
My H100i has been on 24/7 since 2014, never had an issue
That's good to know, i believe it will have a thermal cut off too if the pump does fail.
Going to order it tomorrow.
I was hoping to call them first to check spec is okay etc but you guys have helped out. So thank you.
Final spec
he specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/D7Hyz3PE9e/
It's the non-Wi-Fi variant as far as I am aware..there's nothing in the specs to indicate otherwise
Yeah had a research the wifi variant has wifi at the end of the name would you say the motherboard is abit overkill could knock it down to rog strix x570-f gaming which could free up some funds for a gpu upgrade ?
Stuj
Thanks, just notice the 5800 is now pre-order :( I didn't think the 9 series was much better for the extra £200 ish
As the CPU i wanted is pre order I've changed to AMD Ryzen 9 5900X 12 Core CPU that's also pre order but has extra cores and threads etc
Stuj
Is there anyway to find out how long it will take as the CPU is pre order?
Current estimated lead times: 21 to 23 working days. Components on a pre-order basis will be fulfilled as soon as stock arrives.
Seems a long long time
Windows 10 Professional 64 Bit - inc. Single Licence [MUP-00003]
There's no way of knowing how long it will take, read the stickies to be aware of the current situation regarding CPU's and GPU's.
