Hi Guys,
I'd appreciate it if anyone could give me a bit of help with planning a replacement for my current ageing laptop. I'm looking for something pretty powerful along the lines of a desktop replacement, as unfortunately due to work situations a full desktop just isn't viable for me. Mobility isn't an issue, this thing will likely just sit on my desk and only be moved when I'm moving location every 3-6mths.
The machine need to be able to cope with some moderately CPU intensive work (light coding/compiling, video editing etc) and I'd hope to be able to play all of the current gen games at around 60fps on high, or as close as possible with a laptop.
So this is what I've gone with so far:
Chassis & Display -- Vortex Series 17.3" Matte (I'd assume the spec below would be fine to power the 17" in games, screen size isn't going to make a difference since the 15" and 17" are the same resolution right?)
Processor (CPU) -- Intel Core i7 i7-4710MQ (2.50GHz)
Memory (RAM) -- 8GB KINGSTON SODIMM DDR3 1600MHz (Would there be any benefit to 16gb I can't really think of any myself and if i do end up needing more ram it's an easy upgrade.)
Graphics Card -- NVIDIA GeForce GTX 880M (I think the 880 is worth the extra cash over the 870 given the hassle of upgrading laptop GPU and I also dont think the next gen will be compatible with the current vortex without a PCS bios upgrade and I'm not sure how reliable they are -- anyone have any advice on this)
Hard Drives -- Two HHD Slots on this chasis first one will take a 750GB WD SCORPIO BLACK 7200rpm drive for storage of music, movies, most games etc. Second is a toss up, I want an SSD for the fast boot times an loading screens, and I've heard there are issues with the Kingston V300 Series. So with that in mind I decided to opt for the Samsung 840 EVO series. The main issue is capacity, 120gb seems tight for windows + any games with important load times (MMORPGs etc), So I'm leaning twords 250gb. Would this be overkill and is 120gb sufficient? This configuration also leaves the mSATA bays free which I'm guessing is the best course of action?
Misc --
DVD/BLU-RAY Drive -- 8x SATA DVD±R/RW/Dual Layer
Memory Card Reader -- Internal 9 in 1 Card Reader
Thermal Paste -- ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (for the cost I'd imagine this is worth it, no point shelling out €2000 and skimping on €10)
Sound Card -- Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack
Bluetooth & Wireless -- GIGABIT LAN & KILLER™ 1202 WIRELESS GAMING 802.11N + BLUETOOTH 4.0 (I believe there are issues with intels wi-fi drivers atm, I'd also appreciate it if anyone could weigh in on the "Killer" packet filtering ability and whether it makes a difference)
Warranty -- Will prob go for standard since I'm in Ireland so the collect and return offers no advantages, but tempted by the golds two year parts cover.
Other Bits and Bobs:
Will probably be shelling out for a cheap-ish gaming mouse and cooling stand, any advice is appreciated on these as my knowledge is seriously limited, especially with the cooling stands I don't know if they are needed or a gimic, but I can imagine that this machine will run hot and I dont want any throttling.
I'd really appreciate any advice you guys have as while I'd consider myself a technically this is my first attempt to create a machine anywhere near this powerful and am sure I've made plenty of first time mistakes. If you want to scrap the build entirely feel free to do so, my budget is around €2000 or £1500.
Misc --
