Desktop for Dragon (Aka Mum)
Amethyst
Hi All,
Thinking about the feasibility of getting my mum an new Pc. Or showing her the need & improvements she can get with a new one ( having issues with old <15+> PC Hp- Advent)
Looking at a budget of £400 to 800.
Usage Word, internet, facebooks games ancestry research and storing photos.
Graphis is not an issue. mainly is startup speed. would it be possible to get small but fast SSD?
what can be obtained at the low end Vs the higher?
How urgent is it? I hear some cheaper motherboards for the 8th Gen Intel lineup are coming out in mid Feb which could be a better value option.
PCS GENESIS G1B CASE + SD CARD READER
Intel® Core™i3 Quad Core Processor i3-8100 (3.60GHz) 6MB Cache
ASUS® PRIME Z370-P: ATX, LGA1151, USB 3.1, SATA 6GBs
8GB Corsair VENGEANCE DDR4 2133MHz (2 x 4GB)
1[SUP]st[/SUP] Hard Disk
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
1[SUP]st[/SUP] M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
NOT REQUIRED
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
Price £657.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-pc/!sT8jyYJAN/
Spending £50-60 more would net an i5 8400, which is a fastre CPU with more cores, but for the uses above I don't think it would make much of a difference.
A cheaper build would be something like:
AMD Ryzen 3 1200 Quad Core CPU (3.1GHz-3.4GHz/10MB CACHE/AM4)
ASUS® PRIME A320M-K: Micro-ATX, AM4, USB 3.0, 6GB/s
1GB NVIDIA GEFORCE 710 - DVI, HDMI, VGA
NOT REQUIRED
STANDARD AMD CPU COOLER
Price £597.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/amd-am4-pc/tWRQwPq35Y/
Which has a weaker CPU and a motherboard with fewer upgrade features. However if a 15 year old off the shelf desktop was still doing okay there's probably not much merit to the more expensive Intel system.
Waiting until mid Feb if that is indeed when the new mobos launch, however, might let you net a system with the somewhat higher performance of the Intel CPU with a cheaper mobo, eliminating the price difference between the two.
Going cheaper than either option would result in meaningfully weaker and out of date CPUs that if you're planning to keep the system another 5-10 years really doesn't seem worth it. Likewise the 120gb SSDs on offer will be quite a bit slower.
Amethyst
Hello,
thanks for your help. this is not urgent. although Dragons birthday is in March. this will not be her present. I have a feeling it's going to take a while to talk her into the need for the new PC. I think her current one was mine about 3 swaps ago. Might take until christmas.
question - Graphics Card
1GB NVIDIA GEFORCE 710 - DVI, HDMI, VGA -- How do you know if this is DVI-I or DVI-D? as i have a feeling her monitor will only suport an analouge connections
I think I would also add
DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Wireless/Wired Networking WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
If her monitor's that old, spend some of the rest of the budget on a cheap 24" 1080p monitor then, for the better resolution and all the things it brings with it like the ability to display programs side by side, etc. A monitor upgrade like that can be a very big quality of life upgrade.
