Defiance V RTX
dinana
I just got my gaming laptop and been using it for two weeks. It is a very good laptop for performance and can run most, if not all titles in max setting. This thing is solid. However like all things there are some major drawbacks. I have noticed that it does get pretty hot on the left side and power button. I have ordered a cooler and will let you know whether this makes a difference. I was told that it does not affect the longevity of the laptop so therefore I left it. In addition, the current fans in the system are very loud but with headphones you would not hear it. Overall, this product is pretty good when compared to larger companies such as Dell, HP, etc.. I enjoy working on this laptop very much.
*PROS*
- Very nice display
- Solid performance
- Very fast
- Not too heavy
- Good design of various modern ports
- Beautiful RGB keyboard
*CONS*
- Can get very hot.
- Display panel is bendy and quite fragile
- Keys are a bit mushy to a typical one.
- InBuilt Speakers very bad.
Images:
3CDC8F47-2E69-4457-B69C-029B3E632396.jpeg Ports
754C5160-F86E-473B-8B81-3E81BFC48927.jpegFront
3AF43199-F33E-48D9-96EE-0D99FBE95DDC.jpeg144Hz 1080p FHD Screen
Overall laptop:
If you have any questions, please feel free to comment them below and I will try my best to answer them.
_________________________________________________________________________________________________________________________________________
Defiance Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo)
Get Total War: Three Kingdoms & More w/ select Intel CPUs!
16GB Corsair 2400MHz SODIMM DDR4 (1 x 16GB)
NVIDIA® GeForce® RTX 2070 Max-Q - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
Choose from 6 Incredible Ubisoft Titles FREE with select SAMSUNG SSDs!
AC Adaptor
1 x 180W AC Adaptor
Defiance Series 4 Cell Lithium Ion Battery (62WH)
Bluetooth & Wireless
2 x USB 3.1 PORTS (Type C) + 2 x USB 3.1 PORTS
RGB BACKLIT UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
Notebook Mouse
INTEGRATED 1MP HD WEBCAM
Promotional Item
Welcome Book
Logo Branding
phitol
*PROS*
- Very nice display
- Solid performance
- Very fast
- Not too heavy
*CONS*
- Can get very hot.
Looks good! I picked up a Defiance V 16" myself a few weeks back and also very pleased with it!
Regarding temperatures, there is always one or two spots in most laptops that get a bit toasty.. I found setting the fans to 'max' reduces this slightly, as does a slight 'undervolt' which is par for the course these days. Ultimately thought an 8750h/2070 produces a stupid amount of heat, and whilst the laptop is superb at expelling that out, the top left of the laptop is where the main exhaust is, so that seems to be the hot spot!
It is normal though, and component life should be fine, although I'd refrain from using the 'quiet' or 'entertainment' profiles for gaming, they reduce the fans but let the CPU/GPU get a bit hot for my tastes, to the point I would then be worried about longevity!
Let us know which cooler you get and how you get on with it, these are quite useful anyway as gaming laptops benefit from a bit more help!
