Defiance III 17.3 for gaming. Check it out and tell me what you think
MrVex98
Defiance Series: 17.3" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™ i7 Quad Core Processor 7820HK (2.9GHz, 3.9GHz Turbo)
32GB HyperX IMPACT 2400MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® GTX 1070 - 8.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
1st Hard Disk
1TB Samsung 850 EVO 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
M.2 SSD Drive
256GB M.2 2280, SATA 6Gb/s (561MB/R, 296MB/W)
NOT REQUIRED
AC Adaptor
1 x 200W AC Adaptor
Intel 2 Channel High Def. Audio + MIC/Headphone + SoundBlaster X-Fi MB3
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0
3 x USB 3.1 Type A, 2 x USB 3.1 Type C AS STANDARD
Defiance Series 4 Cell Lithium Ion Battery (60WH)
DEFIANCE SERIES RGB BACKLIT UK KEYBOARD
DVD Recovery Media
Mouse
So guys, what do you think about this laptop? Let me know in the comments below!
Cheaper cpu, silver warranty and changing the secondary drive for a standard hdd unless there is a specific reason for 1TB SSD drive
MrVex98
I wanted to ask If this specification Will handle everything You throw at this laptop? Anyway thanks for your feedback
You can check benchmarks online for the gtx 1070, it should max games at high settings. My comment is based on spending less to get similar performances. If you are happy with the choice of cpu and components go for it.
MrVex98
The graphics card is a beast, ik that. The CPU and other components are very good as well. Hope it will be sufficient for another 3/4 years.
I would change a few components as they're either causing a slow down or not providing any improvement...
32gb ram down to 16, 32 will never be used by any games in the lifetime of the laptop
I'd lower that CPU to the 7700 as that one will not provide any improvement for 99% of games.
You've opted for a very slow M2 drive that's slower than most SATA SSD's, a proper performing m2 will cost only a few pounds more but for 3 times the performance
Up the paste for improved cooling.
At least silver warranty.
That build doesn't make a lot of sense really. Sacrificing important components for unimportant ones, costing way more than it needs to.
MrVex98
I didnt ask about any potential changes that could be made. I just wanted someone to tell me what this setup is capable of. Thanks in advance
SlimCini
KC and the Sunshine BANNED
Well... we're suggesting suitable changes because your build isn't very good and hugely wasteful of money. It would take 5 seconds to google the benchmarks of a laptop 1070 in games.
You're spending £2266 approx on a gaming Defiance that will game just as well as a £1700 one. You're spending almost £500 on, quite literally, nothing you'll notice. If you want to spend that much than at least get a 17" Octane with a 1080 in it and a better SSD and even that is still a bit cheaper.
