Default Fans On A Custom PC
BigC
Hi
Im thinking of buying a custom PC with this Spec
Choose Your Own Case
BitFenix Colossus Venom
AMD BULLDOZER EIGHT CORE FX-8150 (3.60GHz/8MB CACHE/AM3)
ASUS® M5A97: AM3+ PLATFORM, DUAL DDR3, SATA 6.0GB/s, USB 3.0
2GB NVIDIA GEFORCE GTX 560 - 2 DVI,HDMI,VGA - 3D Vision Ready
500GB SATA-II 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
COOLIT ECO II A.L.C ADVANCED LIQUID COOLER (£59)
2 x 200Mbps HomePlug AV - Create a Wired Network Using Electric Sockets! (£38)
Monitor
24" Widescreen TFT 1920 x1080 5MS, DVI, 23.6" Panel (£119)
DVI-D & HDMI Monitor Cables
1 x 2 METRE DVI-D CABLE (£5)
LOGITECH® K200 USB MEDIA KEYBOARD (£10)
Surge Protection
6 Socket Compact 2M UFO Surge Protector (£9)
I was wondering if default case fans will be fitted by PCSpecialist, Mainly because I'm using my Own case delivered straight from another company and im not sure if it already has fans fitted
tom_gr7
Life Serving
I assume the case will come with the fans already fitted/installed, all pcs will do is connect them up. :)
Wozza63
Biblical Poster
they will fit whatever comes with the case, thats a pretty random looking spec, what are you using it for?
Wozza63
Biblical Poster
just a few odd things, whats your budget
there is no need for the 8 core (i have one for other reasons, sort of) the 4 core bulldozer would be fine
you could use that money for a 570, caviar black HDD and a corsair PSU
would also recommend an iiyama monitor, they are much better
quite ironic, my case is also venom :p Akasa Venom Toxic of course
Corfate
Thats from that case's manufacturers site, and it shows a 120mm i believe at the front and a fan at the top (not sure what size though) so i'd assume it comes with that.
BigC
My Budget is around £1,100
I've now switched to the 24" iiyams LED Monitor and the caviar black HDD, However I'm sticking with the 8 core because I want the pc to be powerful for a long time and I may be running a small minecraft server off of it
Wozza63
Biblical Poster
but then the GPU you have will stop it from lasting longer, how about a six core then? that will last ages on games and let you run a minecraft server, even though minecraft servers really dont require much and games still barely use 4 cores
BigC
What GPU do u suggest
