date and time sync issue
ShuAhm
hi guys
all of a sudden the date and time no longer syncs on boot up from shutdown or sleep.
i have to manually sync date and time on every boot, thats once per day as the laptop gets minimum use (work use)
done a all the recommended steps suggested by others other than change cmos battery. I don't want to do that yet unless I am doing something wrong and there is an easier fix.
any suggestions?
tia
hi guys
any suggestions?
tia
You need to change the CMOS, that's what manages the clock time on a PC.
ShuAhm
Chassis & Display Fusion Pro Series: 15.6" Matte Full HD sRGB 100% LED Widescreen (1920x1080)
Processor (CPU) AMD Ryzen™ 5 Six Core Processor 4600H (3.0GHz, 4.0GHz Turbo)
Memory (RAM) 8GB Corsair 2666MHz SODIMM DDR4 (1 x 8GB)
Graphics Card AMD® Radeon™ RX Vega 6 – 1,500 MHz, 6 Core (with Ryzen 5 4600H)
1st M.2 SSD Drive 256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
Memory Card Reader Integrated Micro-SD Memory Card Reader
AC Adaptor 1 x 90W AC Adaptor Power Cable 1 x 1 Metre Cloverleaf UK
Power Cable Battery Fusion Series Integrated 91WH Lithium Ion Battery
Sound Card 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0 USB/Thunderbolt Options 1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT Keyboard Language FUSION SERIES SINGLE COLOUR BACKLIT UK KEYBOARD
Operating System NO OPERATING SYSTEM REQUIRED
Windows Recovery Media NO RECOVERY MEDIA REQUIRED
Office Software FREE 30 Day Trial of Microsoft 365® (Operating System Required)
It's likely going to be one of these, but if it is you need to verify the polarity is correct for your board.
But you need to check as it could be a standard CR32 like this
