I have recently taken delivery of my Optimus VII laptop, whilst checking temps I noted that my HDD is often sat idle at approximately 60 degrees.
As laptops can often have heat issues, having an SSD sat there roasting away at 60 degrees is not good, not to mention what kind of power draw must it be using on the battery to cause such high temps in the first place?
There are many threads on this problem with this drive (one example: http://forums.crucial.com/t5/Crucial-SSDs/Crucial-M500-240GB-mSATA-overheating-issue/td-p/150690).
People recommend enabling things like DIPM via registry hacks, which some reported have improved temps, but should this be necessary in a brand new laptop? I don't think it should, the drive must be somehow flawed from design.
Can any other forum users report on what temps their drives are hitting on this same model, also what kind of temps they see on other M2 drives like the Kingston one? I will contact PCS about this in due course.
