Hello there
I am monitoring my new PC in idle state using HWMONITOR and it is giving a reading of 118 degrees centigrade on the Mainboard which is obviously excessively high.
The CPU temp is 36/35/44 and the core temperatures vary between 32 and 46 centigrade. This was confirmed by checking in the bios (as suggested by PCS technical support).
I assume if it really was that temperature I would be able to feel the heat.
I have checked around on various forums and there are a number of suggestions that this might be due to the motherboard not having the relevant sensors. Does anybody else have this motherboard that could check their temperatures for me to prove that this is the case.
Thank you
Mick
Thank you
Mick
