Okay I've recently been looking to get a new motherboard and CPU.
I was set on getting an i5-4570 with a Asus B85M-G with *maybe* a cooler to keep the temps nice with would be at the £270 mark.
But now I'm considering an i5-4670K with a Asus Z87-A Motherboard and some cooler but that'll bring the cost upto around the £350-£370 mark.
So I was just wondering is the possible extra of £100 worth it for the performance difference? I've never overclocked before and most likely won't until I start seeing a performance difference in my PC say... 4 years down the line.
Or should I just stick to the 4570 with that mobo/get a better mobo but no cooler/etc?
Price wise, I'm not happy going over the £300 mark but if the performance is that much greater I'll consider it and save up for longer.
Decisions, decisions.
Current System:
AMD Phenom II X6 1055T @ 2.8GHz
8GB GSkill Ripjaws @ 1600MHz
3GB Sapphire HD 7950 Vapor-X OC
500GB VeloCiraptor
640GB WD Caviar Green
I did first look at overclocking my CPU first time ever and the only reason was because I wasn't getting the FPS I expected on Arma 3, but was told it's not worth overclocking my old CPU *Had it for 4-5 years now* so I'm looking at going to Intel.
Current System:
500GB VeloCiraptor
