is there a way for me to figure out the impact of CPU on battery life? I have a good budget for a laptop, but don't want to cripple the battery by over-specifying the CPU.
Are them some stats somewhere online about average battery drain or something like that?
The key processors to compare are:
I'm also interested in how the GPU affects battery. E.g. for the Cosmos II how much will battery life be affected by choosing the GTX850M over the GT840M?
Finally, do CPUs and GPUs use less power when they're not fully used? E.g. if the laptop is not being taxed or doing any 3D magic would all the CPUs/GPUs have similar drain or do some of them have higher "base line" power usage?
Please excuse my ignorance in these matters... there was a time in the past I might have known such things, but these days I'm just a pc user and not up to speed on the technical details!
Many thanks,
Carlito
- i7-4712MQ
- i7-4710MQ
- i7-4810MQ
- i7-4910MQ (probably too expensive)
Many thanks,
Carlito
