lewismichaelbbc
Inwin Mini-ITX Performance BQ660 Case
Their are no options to select a different CPU fan. I will need a more powerful CPU fan in the PC as it will get quite hot and was just wondering if anyone would be able to suggest a CPU fan that would fit into it, that I could purchase and send to the team to fit it?
What do I need to look for when purchasing a CPU Fan? I cannot find any 80x80mm fans that would be much better than the stock cooler? - Are their any water coolers that are small enough to fit into it?
Hope this makes sense.
Thanks - Lewis
Thanks - Lewis
