NightKilling
Recently got the PC, and, while everything is working fine I was just concerned because even under heavy load and going into the BIOS to change settings regarding CPU fans, it seems one of the two radiator fans in the PCS FrostFlow 200 series doesn't work at all. Since from what I know the 9700x doesn't require copious amounts of cooling it doesn't overheat but it is still concerning if I wanted to upgrade to a more power hungry CPU.
There was also some significant cosmetic damage to the case + scratches on the glass, but I am more concerned about the fans as it directly affects performance.
