CPU fan noise
PringlesInside
The amd cpu fans (standard) are quite noisy for me.
Had a nice long chat on livechat with Paul Harrison.
he said http://www.scan.co.uk/products/geli...5-1366-1156-1155-and-amd-754-939-940-am2-am2p
would be a good silent cpu cooler.!
I would like to ask if anyone knows any better silent ones?
and if i should install the cpu cooler myself (someone whos never done it) and what guidance can you give me?
Anyone who helps with get a few +reps ,
p.s. Thank you Paul Harrison. He is a great guy!!! :santa:
Sleinous
Ye the Tranq is a good one, the Frozer II is also quite a quiet one.
As for replacing it, you will need some TIM, Arctic Silver MX5, IC Diamond, Shin Etsu, whatever you prefer, depending on size of CPU you'll need a small/medium/large pea sized drop on the top of the chip before placing your new cooler UNLESS it comes pre-TIMed. Either way you will still require something dry and non-conductive to wipe off teh TIM that may have remained on your chip from the stock AMD cooler. You can also pick up a twin pack of ArctiClean 1 & 2, 1 for emoving teh TIM and 2 for cleaning ready for new cooler.
Apart from that, its all quite straight forward and the best thing is not to panic :)
PringlesInside
got a link the the frozr one?
cheers
PringlesInside
its a bit cheaper which is good
but which one is the better? Im looking for silence/silent noise
and also i will look to overclock my CPU at the start of 2012
