Cpu fan fit
Teaz
you might be able to, you should check the spacing since its dimensions are 125 x 153 x 74 mm (WxHxD). a good start is the height then checking if it blocks or covers/obstructs anything like ram slots by seeing the area coverage of the cooler. its just about abit bigger than the tripple copper and the copper fits the t900 with the side fan.
