Right, well, I was messing around with the OCing tools on the ASUS TurboV EVO program and decided to run an automatic overclock. It did it's thing where it changes some settings, reboots, and changes some settings and tests them and reboots. And it went up to the maximum the PC could handle and crashed. Fine, I restarted and all was well.
I was then curious as to what the Turbo Key section could do for performance. So I pressed it. The computer froze, so i pressed the reset button and it came on, fine again, only this time just after the POST beep, there were 6 more beeps and a message saying 'CPU FAN FAILURE; F1 TO RESUME'. Shortly after, the CPU fan spooled up a bit and became annoyingly loud. Now everytime I start the computer I get that message, and the fan is louder than usual. I know there cant be a CPU fan error as it is spinning fine, shooting out loads of cold air, and I checked the CPU temps. in the BIOS and they were around 36 degrees.
So, what can I do to stop the message and get the fan to spin quietly? Can I just reset the system so that it's like it was when it was first built?
p.s. I have already checked the fan's power cables.
