Cosmos XI Series: 15.6" Review
smatharu
Earlier this week I received my 15.6" COSMOS IX laptop. After 7 years using my old PCS laptop, it was time for an upgrade and so far, I am absolutely chuffed.
The spec I ordered was:
Chassis & DisplayCosmos Series: 15.6" Matte Full HD 144Hz 45% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
Memory (RAM)16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® GTX 1650 - 4.0GB GDDR5 Video RAM - DirectX® 12.1
Change to: NVIDIA® GeForce® GTX 1650 Ti - 4.0GB GDDR5 Video RAM - DirectX® 12.1
1st Storage Drive120GB ADATA SU650 2.5" SSD, SATA 6 Gb (520MB/R, 320MB/W)
1st M.2 SSD DriveNONE
Change to: 256GB INTEL® 760p M.2 NVMe PCIe SSD (up to 3210MB/sR | 1315MB/sW)
Memory Card ReaderIntegrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor1 x 120W AC Adaptor
Power Cable1 x 1 Metre Cloverleaf UK Power Cable
BatteryCosmos Series Integrated 4 Cell Lithium Ion Battery
Sound Card2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & WirelessGIGABIT LAN & KILLER™ Wi-Fi 6 AX1650 M.2 GAMING + BLUETOOTH 5.0
USB/Thunderbolt Options1 x USB 3.2 PORT (Type C) + 1 x USB 3.2 PORT + 1 x USB 2.0 PORT
So as a bit of a background in why i chose this: I work in SEO so use Google Chrome a lot along with other applications such as Screaming Frog which require a half decent spec, in particular a quick HDD and plenty of RAM. Gaming is not a big thing for me, although if I do fancy it, I would like something which won't run at 10fps :p
It took me a while configuring this because I wanted to make sure it will last for a good time. Looking on these forums was EXTREMELEY helpful and I cannot recommend it enough to help you build your spec. Some things which I found in particular:
  1. - Buying 2 ram slots as apposed to 1 of the same size
  2. - Using a M.2 NVMe hdd for an even quicker hard drive performance
The first issue with ram, my initial thought was to buy 1 slot of 16gb so that it leaves another slot free for later, but in reality, I'm not going to need more than 16gb anytime soon, so opting for 2 slots of 8gb would be a much faster solution (as recommended in the forum). Secondly, I already have a 500gb SSD drive which I've put in, so I opted for a standard 120gb SSD which I was going to put in another laptop, but I read on the forum that using M.2 NVMe is much faster, and that's where I decided to upgrade that element - again thanks to the forum for this advice.
Graphics card wise, for the extra money (which wasn't much), I just thought go for the Ti version. I'm not a huge gamer but If I do want to play, this laptop will handle it fine.
The keyboard is really nice but the touch pad does take getting used to, which isn't an issue as I mostly use an external wireless mouse anyway.
I took out the 120GB SSD and replaced it with my 500GB SSD and doing this was no problem. There are a lot of screws at the back, but once off, I just needed to first remove the M.2 hdd which gave me access to the SSD so that I could change it. No issues and it took literally 10 minutes.
I had a very strange issue with my wifi. At home, my router runs on 2 channels; 2g and 5g. When I connected to the 5g channel, it was really slow, unusually. And strangely it would be like this for about 5-10 minutes and then all of a sudden it sprung to life and ran at normal speeds. I tested on the 2g channel and weirdly that ran to normal speeds straight away. I updated drivers, made sure power settings were not affecting the wifi card and weirdly, I think it's fixed it. That was the only issue I had with this laptop but it doesn't seem an issue anymore.
Next, i'm going to buy a cooling stand for this as the fans are at the bottom, so not much room for the hot air to escape. Can anyone recommend a cooling stand? Seen a few on Amazon. I don't need the Rolls Royce of fans, just need something to keep this laptop extra cool when needed.
Cracking laptop!
I recently got a cosmos to a similar spec, think about the only difference is i got a 500GB SSD from the start and a 1TB M2, and am really pleased with it as well.
This is the second case I've read of 5GHz running slow to start off with, can't remember if mine did or not.
